View and Delete Debug Files
Use this procedure to view and delete debug files.
Delete debug files to free space in the internal flash. As a best practice, delete these files to ensure enough space exists in intflash. New debug files do not overwrite old debug files. You must remove the file; otherwise, enough free space might not exist in the intflash to store the core dump if the switch fails or enough space might not exist for you to transfer a new release to the intflash of the switch to upgrade your switch.
The debug-file remove command can delete the following types of files:
core
archive
PMEM
dmalloc
flrec
wd_stats
If you want to delete a specific file, you must use the remove command. For more information, see VOSS Command References.
The following example shows how you view all debug files for all slots.
Switch>show debug-file ================================================================================ Core Files ================================================================================ Directory: /intflash/coreFiles/1 1. File: core.logServer.20120611084204.1.tar Size: 60928 bytes Created: Mon Jun 11 08:42:04 2012 2. File: core.trcServer.20120611084213.1.tar Size: 60928 bytes Created: Mon Jun 11 08:42:13 2012 3. File: core.logServer.20120611164647.1.tar Size: 64000 bytes Created: Mon Jun 11 16:46:48 2012 4. File: core.trcServer.20120611164652.1.tar Size: 64000 bytes Created: Mon Jun 11 16:46:52 2012 5. File: core.dbgServer.20120611164700.1.tar Size: 64000 bytes Created: Mon Jun 11 16:47:01 2012 6. File: core.logServer.20120611164740.1.tar Size: 64000 bytes Created: Mon Jun 11 16:47:41 2012 Remote CP Directory: /intflash/coreFiles/2 1. File: core.coreManager.x.20120612085548.2.tar Size: 1162240 bytes Created: Tue Jun 12 08:55:49 2012 2. File: core.coreManager.x.20120612085602.2.tar Size: 478208 bytes Created: Tue Jun 12 08:56:02 2012 3. File: core.coreManager.x.20120612085553.2.tar Size: 1170432 bytes Created: Tue Jun 12 08:55:56 2012 4. File: core.coreManager.x.20120612085558.2.tar Size: 1883136 bytes Created: Tue Jun 12 08:56:00 2012 ================================================================================ Archive Files ================================================================================ Directory: /intflash/archive/1 1. File: archive.20120611083021.1.tar Size: 34296320 bytes Created: Mon Jun 11 08:30:22 2012 2. File: archive.20120611163454.1.tar Size: 31108096 bytes Created: Mon Jun 11 16:34:54 2012 3. File: archive.20120611164354.1.tar Size: 31792128 bytes Created: Mon Jun 11 16:43:55 2012 4. File: archive.20120611164507.1.tar Size: 31881216 bytes Created: Mon Jun 11 16:45:08 2012 Remote CP Directory: /intflash//archive/2 1. File: archive.20120611163507.2.tar Size: 30903296 bytes Created: Mon Jun 11 16:35:08 2012 2. File: archive.20120611164408.2.tar Size: 31314432 bytes Created: Mon Jun 11 16:44:09 2012 3. File: archive.20120611164521.2.tar Size: 31367168 bytes Created: Mon Jun 11 16:45:21 2012 Directory: /intflash/archive/4 1. File: archive.20120611163515.4.tar Size: 4725760 bytes Created: Mon Jun 11 16:35:18 2012 2. File: archive.20120611164416.4.tar Size: 5639168 bytes Created: Mon Jun 11 16:44:20 2012 3. File: archive.20120611164529.4.tar Size: 5760000 bytes Created: Mon Jun 11 16:45:33 2012 Directory: /intflash/archive/SF4 1. File: archive.20120611163536.SF4.tar Size: 1550336 bytes Created: Mon Jun 11 16:35:40 2012 2. File: archive.20120611164436.SF4.tar Size: 1781248 bytes Created: Mon Jun 11 16:44:39 2012 3. File: archive.20120611164549.SF4.tar Size: 1811968 bytes Created: Mon Jun 11 16:45:53 2012 ================================================================================ PMEM Files ================================================================================ Directory: /intflash/PMEM/4 1. File: pmem.20120607194023.4.bin.gz Size: 571048 bytes Created: Thu Jun 7 19:40:23 2012 ================================================================================ DMalloc Files ================================================================================ ================================================================================ Flrec Files ================================================================================ ================================================================================ WdStats Files ================================================================================ Directory: /intflash/wd_stats/4 1. File: wd_stats.log.backup Size: 2311 bytes Created: Mon Jun 11 09:25:07 2012
The following example shows how to view only core files on the switch.
Switch#show core-files ================================================================================ Core Files ================================================================================ Directory: /intflash/coreFiles/1 1. File: core.1353113115.lifecycle.CP.1.gz Size: 139406 bytes Created: Fri Nov 16 19:45:15 2012 2. File: core.cbcp-main.x.20121114043335.1.tar Size: 14059520 bytes Created: Wed Nov 14 04:35:36 2012 3. File: core.cbcp-main.x.20121114045202.1.tar Size: 12809728 bytes Created: Wed Nov 14 04:54:03 2012 4. File: core.cbcp-main.x.20121114050825.1.tar Size: 12638720 bytes Created: Wed Nov 14 05:10:26 2012 5. File: core.cbcp-main.x.20121114122506.1.tar Size: 13020160 bytes Created: Wed Nov 14 12:27:07 2012 6. File: core.1353336274.lifecycle.CP.1.gz Size: 139390 bytes Created: Mon Nov 19 09:44:34 2012 7. File: core.1353319337.lifecycle.CP.1.gz Size: 139404 bytes Created: Mon Nov 19 05:02:17 2012 8. File: core.cbcp-main.x.20130122182946.1.tar Size: 13683712 bytes Created: Tue Jan 22 18:32:08 2013 9. File: core.cbcp-main.x.20130220143809.1.tar Size: 13969920 bytes Created: Wed Feb 20 14:38:10 2013 10. File: core.cbcp-main.x.20130225155025.1.tar Size: 13526016 bytes Created: Mon Feb 25 15:50:25 2013 11. File: core.cbcp-main.x.20130225155407.1.tar Size: 12674560 bytes Created: Mon Feb 25 15:54:07 2013
The following table defines parameters for the show core-files command.
Variable |
Value |
{slot[-slot][,...]} |
Displays the core files for the slot that you select. |
The following table defines parameters for the show debug-file command.
Variable |
Value |
all |
Displays all types of debug files |
Displays debug files for the slot that you select. If you do not select a slot number, the device displays all types of the archived debug files present in a slot by slot basis. If you select a slot number, the device only displays archived files for the slot you select. |
The following table defines parameters for the debug-file remove command.
Variable |
Value |
all |
Removes all types of debug files in all slots. If you use the option all with the remove debug-file command, then the device deletes all types of debug files, including the latest debug files. |
